Mike Likens
- Jul 9, 1999
I have been reading about IB subs and am intrigued and confused. It sounds like an easy and fun project. I believe I have the ideal placement for one as well.
I'm thinking of using the area under my stairs. But I have some specific questions maybe someone can help me with. I'm considering the Dayton IB 15" drivers(2) and the PE 250 watt plate amp with remote. How do I wire the 2 woofers to the plate amp? Do I jumper them in parallel or in series? Do these drivers come with dual imput terminals?
Would dual Tempest be a better driver? Should I be using a stereo amp? Sorry for the simple questions just want to make sure I know what I am doing.
Also, can the baffle be mounted on the backside of the 2x4s instead of the side closest to the HT room? I am trying to figure out a way to keep 1.5" of MDF from protruding into the room.
Any suggestions or advice would be greatly appreciated. Thanks is advance.
Mike
Mike
