Inexpensive DVD Player?
Discussion in 'Archived Threads 2001-2004' started by Mike_Boulanger, Dec 16, 2001.
  1. Mike_Boulanger
    Mike_Boulanger Stunt Coordinator
    Mar 5, 2000
    86
    Can anyone recommend an inexpensive DVD player that is reliable? Looking for one to give as a gift.
    There is a Samsung, I believe model M101 that runs about $120 on-line that I have been checking out.
    However, I'm not familiar with how Samsungs are compatibility-wise, reliability-wise, etc...
    Normally I'd try to stick with the Sony/Toshiba/Panasonic players, but can't find one in that price-range.
    Don't mind buying on-line if I can save significantly. I'd like to keep it in the $120 range, but wouldn't mind spending slightly more if I get a better built player.
    Any suggestions appreciated..
    Thanks!
  2. David Cohn
    David Cohn Extra
    Jan 13, 2001
    19
    DVD players are one area where a little money can still get a quality product. I recommend you check out Yahoo shopping/electronics/DVD players ... be confident ordering from a five-star retailer.
    Take a look at the Sony's ... 300 and 400 models. Both are around $170.
    Toshiba makes a nice entry-level player ... about $160.
    Make sure you add the cost of an s-video or component cables. Don't use the low quality composite cable found in the box.
    Do you want a five-disc carousel? Both coaxial & optical outputs? These features are nice to have but will increase the price.
    Good luck.
  3. Keith_R
    Keith_R Screenwriter
    Jun 16, 2001
    1,170
    FL
    Kyle
    I would recommend you stay away from Samsung, from what I've heard they don't make very good DVD players, with compatibility issues, skipping ecetera. Try to look for a Panasonic, Sony, or Toshiba in your price range.
  4. Barry BB
    Barry BB Stunt Coordinator
    Nov 28, 2001
    168
    For a good basic non-progressive player try the Panasonic RV31 which you should be able to get at Best Buy for $169. A little higher than your $120 price but if you can afford the extra $49 it is a great low end player.
  5. Scott Merryfield
    Dec 16, 1998
    12,167
    988
    9,110
    Best Buy was advertising an entry-level Pioneer player in this weekend's add for $129.
  6. Stephen L
    Stephen L Second Unit
    Jan 3, 2001
    358
    Costco has the Toshiba 1700 for $129 and of course the $99 Daewoo player, for the extra 30 the Toshiba is a great choice.I believe BJs also has the Tosh at this price. The Pioneer at BestBuy is a good deal ,also believe its that price at Costco. And finally Target has an Oritron for $89.
  7. Albert M
    Albert M Stunt Coordinator
    Jun 19, 2001
    222
    It is the Pioneer DV341 that is at Best Buy for $130. Go with Pioneer, Toshiba or Panasonic.
  8. DavidAM
    DavidAM Second Unit
    Sep 30, 2001
    375
    This weekend my local Sears had the discontinued Panasonic RV30 for $129 if you don't mind last years model and they have them at the Sears in your area.
  9. Mike_Boulanger
    Mar 5, 2000
    86
    Thanks for the help, guys
  10. BrianKM
    BrianKM Stunt Coordinator
    Jan 15, 2001
    106
    Check out Ben's Bargains for a Toshiba SD-1700 for $135 shipped from Amazon. I used a similar deal a year ago to get an SD-1600 and have been extremely happy with it.
