Inexpensive cables for surround, higher end for fronts?
Discussion in 'Archived Threads 2001-2004' started by Don K, Jan 1, 2002.
  1. Don K
    Don K Agent
    Dec 10, 2001
    26
    After reading alot of post on cables I'm still not sure that spending alot of moeny for cables makes a difference over Home Depot's wire. I have talked to two speaker companies than felt that high end wires did not make an audible diffence worth the extra money. My thought is to use mid to high end cables for the front which will not require long runs and use cheaper(Home Depot wire) for the rear surrounds and the sub. Is my assumption that wiring to the surrounds is not as critical correct? This will save me money and yet allow the use of more expensive wiring for the fronts and center which produces most of the sound anyway.
  2. Michael Cook
    Michael Cook Stunt Coordinator
    Dec 25, 2001
    238
    Since you talked to two companies that said high end cables won't make a difference, I would go with Home Depot all the way around. It will save you a few bucks.
  3. Mark Austin
    Mark Austin Supporting Actor
    Dec 28, 1999
    639
    Don K,
    That pretty much what I do. More cost effective, and there just isn't enough information coming out of the rears to justify the cost, IMO.
    You likely won't get much of an opinion from any speaker manufacturer, as they aren't in the business of listening to differnt cables. Some that I have talked to say that their are changes in the sound, but won't go as far as recommending a certian brand. It's not their business to sell someone else's product, afterall.
  4. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    Yes use better premium cables for the front speakers (LCR) and 12 awg for the surrounds. By premium I dont mean boutique or expensive! Something like lower end Nordost, Kimber etc..
  5. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    110
    If you are running wire in the attic or down through the walls I would definitely get UL listed in-wall wire. I just replaced my two 70' Home Depot 12-gauge runs with AR ProSeries 14/4 runs. It ran me $.50 a foot, which I consider a bargain. You can dress the ends up (I did) to make it look like expensive boutique wire. [​IMG] I ordered it from AudioAdvisor .
    I chose the 14/4 wire over the 14/2 wire because of the extremely long run, then just doubled up on the ends, effectively making it 11-gauge wire. The 14/2 would be fine for shorter runs.
    Good luck, and Happy New Year!
    Pete
  6. Don K
    Don K Agent
    Dec 10, 2001
    26
    Thanks Pete. The runs are shorter than 40 feet and they will be inwall.
  7. Brian_C
    Brian_C Stunt Coordinator
    Feb 16, 2000
    51
    I would use Home Depot or Sound King 12 gauge all around, but if you do want to use premium cables, I'd only stick to the fronts as well. The rears don't play much sound at all and they are generally used only for effect.
