In wall wiring
Discussion in 'Archived Threads 2001-2004' started by Kevin*Open, Dec 9, 2002.
  1. Kevin*Open
    Kevin*Open Auditioning
    Nov 24, 2002
    4
    Quick question,
    I have been shopping for in wall wiring in my new home, why would you need more than 2 conductors, wouldnt you just need 1-black and 1-red, why do they offer four conductor wires. Thanks in advance.
    Kevin
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Kevin,
    Four conductor wire is great for some in-wall wiring applications.
    For instance, you would only need to pull a single cable to do both surround speakers.
    Or, you could go ahead and pull two four-conductor cables and know you would have spare conductors if there was ever a problem. Or, the extras would be in place for a future up-grade, like a rear center speaker or two.
    Wayne A. Pflughaupt
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    My advice would be to run three sets of wires to the rears so you are setup for the rear-center speaker that is becoming popular with EX systems.
    I would also run enough wire to create a un-broken link to your speakers. Run the wires through electrical outlet box's and buy blank face-plates for about $0.50 ea. Drill holes for the wires and this will give you a neat appearance. Later if you want, you can cut the wires just outside the faceplates and install covers with speaker binding posts.
    Check the DIY fourm for other in-wall wire ideas.
  5. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
  6. Kevin*Open
    Nov 24, 2002
    4
    Thanks for the info and advice, I appreciate it.
