Domonic A
- Sep 29, 2003
- Domonic Ableidinger
I am wondering what all of you have used for running wire in your ceilings and walls. I neeed to run about a 30' run through the basement ceiling for an FP. I also wnat to run tubing in the wall (2x4 studs) for the speakers and would like to use gang boxes for the locations and have the tubing come in one side and continue out the other side to the next box.
The tubing needs to be flexable to snake it through the I joists and studs. I will also need a couple of 90 degree bends. I would like 2" for the ceiling and 1-1/2 for the walls.
Thanks for your help.
Domonic
Domonic
