in-wall vs. ceiling surround
Discussion in 'Speakers & Subwoofers' started by Fran Lu, Feb 16, 2004.
  1. Fran Lu
    Fran Lu Extra
    Jan 26, 2004
    24
    I have a sofa right up against the wall. The HT area will be roughly 15" x 15". One side is wall, the other open. If you're facing the sofa, there's a small window to the left of it. My dilemma is whether to go with ceiling or in-wall. Satellites are not an option as the only place I could put it would be right in front of the window. Not my first choice.
    Which route should I go? Also, will electrical wires cause an interference w/ the speakers?
    Thanks for your help!
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,265
    72
    9,110
    Corpus Christi, TX
    Wayne
    The in-walls in your situation, with the sofa against the wall, would need to be to the sides firing towards the sofa. It would not be good for the in-walls to be in the wall behind the sofa firing over the viewer’s heads towards the front of the room. So I guess in-ceiling is your only option.
    As long as parallel speaker runs are a foot or so away from the electrical, you’ll be fine.
    Wayne A. Pflughaupt
  3. Fran Lu
    Fran Lu Extra
    Jan 26, 2004
    24
    But if the speaker wires are not at least a foot from the electrical, but cross at a 90 degree angle, they should still be okay, right?
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,265
    72
    9,110
    Corpus Christi, TX
    Wayne
    Yes - forgot to mention that. [​IMG]
  5. Fran Lu
    Fran Lu Extra
    Jan 26, 2004
    24
    cool thanks!
