In Wall Speaker Wire
Discussion in 'Home Theater Projects' started by Bill*L, Oct 10, 2003.
  1. Bill*L
    Bill*L Extra
    Aug 11, 2003
    24
    Looking for recommendations on what type speaker wire to use in my HT. I have typically not paid attention to whether speaker wire is UL certified or not but I want to do it right this time being that I am building this theater from scratch. Talked with my local retailer and he recommended Tributaries @ $4foot. Being that I need about 200 feet of this, I thought it was kinda expensive. I looked at Monster Cable and found some for about .75foot. Am I really going to notice the difference between these two types of wire? Any recommendations on a better wire for the money?
  2. Steve Adams
    Steve Adams Second Unit
    Oct 20, 2001
    432
    go to home depot, get the 12ga there, that will be fine....
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    I’ll second Steve’s response. If you happen to be running in-wall for the front speakers you might use the Tributaries, but only if you believe high-priced cable make a difference. For the rear surrounds, however, use the cheapest 12ga. you can find.
    Wayne A. Pflughaupt
  4. Steve Adams
    Oct 20, 2001
    432
    well I just ran my wire, my speacialist told me that 14 is fine, 12 is overkill for my appication, so I used ultralink 14ga audiophile grade wire. very easy to work with, not to big. and much cheaper. I would have paid 1.00 ft for 12 ga. up here, but i got the 14, for .40 a ft. great deal on great wire. im pleased.
  5. Ed O'Neill
    Ed O'Neill Second Unit
    Mar 20, 2003
    333
