in wall speaker questions...
Discussion in 'Speakers' started by RobG, Jan 1, 2004.
  1. RobG
    RobG Stunt Coordinator
    Jan 22, 2000
    51
    I am buying a new home and am considering going to in-wall speakers due to the layout of the room and asthetics. Unfortunately the walls are up so I will need to run wire and need suggestions on how to go about it. Also, I have a Mits 55805 and with the set where I want it, the speakers will be to the rear of it. How will this degrade sound and if it will be significant would a cabinet set-up around the set be better. Any other tips anyone may have would be appreciated. Thanks.
  2. Dave Manning
    Dave Manning Auditioning
    Jan 2, 2004
    6
    You said the walls are up? With Drywall?
    If so, your going to need to get up in the attic and wallfish some speaker wire..
    IMO, I'd use some Speakercraft aim-5's for rears and and bookshelfs up front.
