In Wall Speaker Connectors
Discussion in 'Speakers' started by Matthew Jon, Jun 7, 2003.
  1. Matthew Jon
    Matthew Jon Auditioning
    Jun 4, 2003
    13
    The situation is that I have a system that is built IN WALL and the speakers will be outside that wall, and the Connections from the Receiver will be on the inside of the wall. I need to find some In-Wall Connectors or something of that liking. I found an Outlet that has a 1/2" hole in the middle for pulling some sorts of Wire. And I have seen an In-Wall connector that has the speaker connection built in the outlet. This type cost or runs for about 10 bucks at Best Buy. The first one runs .29 cents at Menard's.
    Would it be worthy to get the actual speaker connector or go with the cheap hole in the Outlet for sliding the Speaker wire from? This way there is no splits from the receiver to the Speaker.
    Matt
    P.S. Mounted speakers or Speaker Stands for the Back Channel Speakers.
  2. Mathew Shelby
    Mathew Shelby Second Unit
    Dec 5, 2002
    344
    This has been long in debate on the forum. Personally, I believe that the less connections you make the better off you will be. It also depends on how clean an install you want. Personally, I use the .29 plates and then have the speaker cover it you so you don't even see it making it a non-issue.
