In-Wall Component Video Modules
Discussion in 'Home Theater Projects' started by Jeff_Nash, Aug 25, 2003.
  1. Jeff_Nash
    Jeff_Nash Auditioning
    Aug 25, 2003
    I'm finishing up a remodel of my home and have included either in wall wiring (speaker, video, data, etc) or a pull string for all needed applications. My question is: I want to run the component video wiring in wall as well. I have not been able to find any in-wall jacks specifically for component video (such as Leviton's quick port modules). Does anyone have any suggestions for a solution on this? Also, for the wiring, is there any prefered cable/manufacterer/type of wire that will provide the best solution?
    Thanks in advance!
  2. BenSC
    BenSC Stunt Coordinator
    Jun 19, 2003
    190
    Partsexpress.com has S-Video, and a triple-audio which I think could be used for component. PN 261-344.
  3. Brian Corr
    Brian Corr Supporting Actor
    May 10, 1999
    535
    Markertek can make custom wall plates with whatever connection you may need. Check them out.
