Setting up new system - Adire Kit281 mains, LCC, Kit81 surround, & mid-Q sealed Tempest. I've been following and posting on a few forums hoping to better understand the issues and was hoping to get feedback on my measured response.
The 'room' is about 15x23. The viewing/listening area at one end and is setup transverse to the major axis of the room. Another room takes an 8x8 bite out of the corner of the room at the opposite end. The reciever (Denon 1803) is setup with all channels crossed over at 80hz. The sub amp (AVA250) low pass is disabled. Phase is set to 0. The sub is at the 5' mark along the 15' wall, a few feet closer to the listening position than the mains and a few feet to the side. Measurements were taken with the Radio Shack SPL meter (corrected using the values at http://www.danmarx.org/audioinnovation/rsmeter.html) playing the Stryker Audio test CD.
Response graph:
www.midcoast.com/~swanton/gs/ht/response1.jpg
I'm assuming the 16db peak around 36hz is a room mode and best corrected with EQ, and that the crater at 160hz is a room null and that I can't 'make this go away' electronically.
Theres a sharp 6.5db null at 80hz. With the sub amp low-pass disabled I'm assuming this isn't a crossover issue. I can experiment with the phase setting but where its an even multiple of the near-40hz peak is this also probably room related?.
Any feedback to verify or refute these assumptions and/or info on understanding in-room response is much appreciated.
Response graph:
