Javal
Grip
- Sep 3, 2008
- Jason
Hi all, one of many posts. Please check out my other posts in other sections and offer feedback if you can. Would very much appreciate it, lots of great information on this forum.
Background: I am building a new home which is a walkout and we are finishing the basement and are putting a projection home theater in. The room with have blackout blinds to light control. The room size is open concept 32 long X 15 wide. Plan to use majority of room (18 X 15) for the home theater and the other have will be bar, siting, etc.
The more I deal with a home theater store/designer the more I am thinking I want to do most of it myself. Please check my other posts in the hardware sections and offer feedback on what they are trying to sell me vs what you think I may actually need.
They are promoting using Truaudio 8" Revolve Speakers Found Here TruAudio : : Home Theater In-Ceiling for all my speakers, including the fronts and center... I do not feel comfortable using at the front, as I am using a projector I will be 11-12' from the screen and do not think the in-ceiling will be the way to go for the fronts. However, for the backs they seem like a solution. I can not find any reviews on these speakers or the company. Has anyone heard anything. I like the idea of the cones being adjustable and slanted. Any other options.
The sub they are trying to sell is the Sunfire HRS 8". Seems like a good sub, but I wonder if I really need something that "advanced". Are they just trying to sell a more expensive sub, or is it a good value for the $$? I have lots of room, so if I can purchase something that may be a bit bigger but cheaper, it may be the way to go.
Thanks in advance.
Thanks in advance.
