Improving Radio Reception
Discussion in 'Archived Threads 2001-2004' started by Ten_Smith, Mar 1, 2002.
  1. Ten_Smith
    Ten_Smith Stunt Coordinator
    Dec 21, 2001
    76
    What is the best way to inexpensively (< $30) improve the radio reception on my soon-to-be-purchased Denon 1802 receiver. I'd like to improve both AM and FM, but will take advice on either.
    Do things like the "TERK AM/FM Antenna Tower" work? Incidentally, its available at circuit city for $20.
  2. John Morris
    John Morris Guest
    Ten: I use a huge Radio Shack FM/TV antenna which I put up in my attic and run some RG-6 coax cable from there to my tuner. It is the only way that I can get solid reception of FM stations located about 60-80 miles away from me. The antenna only cost me around $29 or so.
  3. Gerard Martin
    Gerard Martin Second Unit
    May 22, 2000
    366
    Local conditions surrounding your area
    will determine how well an antenna will
    or won,t work. Would suggest try that
    CC antenna out, see if your satisfied
    if not bring it back, you have nothing
    to lose other than a possible second
    trip.
