Impression of 8" Bolt Sub Kit from Raw Acoustics
Discussion in 'Home Theater Projects' started by Mike_Ra, May 16, 2004.
  1. Mike_Ra
    Mike_Ra Auditioning
    Apr 10, 2004
    I recently purchased the 8 inch Bolt sub woofer from Raw Acoustics. This sub comes in kit form or fully assembled. It has a one cubic foot cabinet, an 8 inch Tang Band driver, and a 100 watt plate amp. I also included a 10 inch passive radiator as an option. I use this sub for home theater in a 12 x 20 room. I was apprehensive that an 8" sub could provide a lot of bottom end for home theater. However, I was very impressed with this sub and it sounds like it should be much bigger. The sub also sounds great with music DVD's and CD's. Fantastik sound for the money and it doesn't take up a lot of space. Easy to build also.
    Not affiliated with the company, just a very satisfied customer.
  2. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
    [/url]
  3. Jason Dalton
    Jason Dalton Stunt Coordinator
    Feb 20, 2004
    174
    STOP!! Get on the ground and put you're hands behind your back. Its the GRAMMAR POLICE!![​IMG]
    Maybe we can compromise and say 'fantastick'?
  4. kai m
    kai m Auditioning
    Apr 16, 2004
    8
    Thats great to hear, I'm going to use 2 in a much bigger box and I've been worried about being underwhelmed.
  5. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    The TB W8 is a nice little woofer. I built a dual driver unit for a friend which turned out nice. This month's Audio Xpress has a write-up on "apartment" subs and the W8 did very well there also. Good choice for a small inexpensive sub.
  6. Patrick_L
    Patrick_L Second Unit
    Oct 18, 1999
    271
    i'll have to check that out for a buddy that just moved into an apt.
    Rory, a bit anal, no?
