"Imperial" or "English" measuring devices illegal in Australia?
Discussion in 'After Hours Lounge (Off Topic)' started by JamesCB, Mar 15, 2004.
  1. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    I was browsing one of those "movie mistake" sites and came across this in a Finding Nemo thread:
    "Factual error: In the scene where the fish tank has been cleaned by the newly installed laser fish cleaner, the machine states that the water temperature is '82 degrees.' In Australia the celsius scale is used; therefore, it should be about '28 degrees.' It is actually illegal to import or sell any instrument using 'Imperial' scales. You couldn't buy a Fahrenheit thermometer if you tried."
    Is this true? Is it illegal to own Imperial measuring devices in Australia? I find this very hard to beleive.
  2. Dennis Nicholls
    Dennis Nicholls Lead Actor
    Oct 5, 1998
    8,937
    347
    Boise, ID
    Dennis
    Sounds crazy to me. I know that English-measurement "headspace gauges" for those working on Lee-Enfield rifles are made and sold by an Australian firm. The .308 British cartridge is still made in Australia. Cars made in Australia (e.g. the early 1990's Ford Capri) are sold with many English-measurement parts (e.g. tire diameter - make that tyre dyameter). I'm sure some guys from OZ will check in here soon.....
  3. Lance Nichols
    Lance Nichols Supporting Actor
    Dec 29, 1998
    726
    It could be granfathered. Here in Canada we have metric weights and measures, but you can't, for the life of you buy screws, nails, etc. in metric units.
    I went looking for an 11mm screw the other day, and could not find any. Had to resort to a 9/32.
    Most thermometers are have c and f scales, although if anyone tells me what the temp in in F, I have to google to get the "real" temp.
    Weights are similar. I know what I weigh in lbs, but not in kilos, even though my medical records have my weight in kilos. Same with height.
    Firearms are still sold in caliper, with the exception of modern cartridges, such as a 9mm, or 10mm. You can buy .223 rounds either as .223, or 7.89MM, IIRC. Tires are sold using a combination of imperial and metric. Tread width is in mm, rim diameter is in inches...
  4. Nick Sievers
    Nick Sievers Producer
    Jul 1, 2000
    3,481
    It can’t be illegal, our company uses Imperial measuring devices everyday. All measuring tapes have both scales on them and you go onto any building site or into any machine shop and no doubt they use both. Imperial is not taught in our schools so when I left it made it a bit hard to adapt, but it certainly isn’t illegal. However it would be hard to find a thermometer that reads Fahrenheit.
  5. Dennis Nicholls
    Oct 5, 1998
    8,937
    347
    Boise, ID
    Dennis
    Lance,
    The .223 and 5.56mm are roughly the same cartridge. See www.fulton-armory.com/556-vs-223-Chambers.htm for a safety caveat.
    7.89mm is bigger than a .30 cal (7.62mm)! [​IMG] Remind me to check all ammo you try to load into one of my rifles....
    During WWII so many American SAE bolts and nuts were imported into the UK that they generally superceded the British-standard thread pitch. So nowadays the inch-pound system is called "American standard" in the UK whereas we in the US call it "English". I guess nobody wants to take the blame for it anymore.
  6. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    your height is in kilos too? better switch to a more qualified doctor! [​IMG]
    CJ
  7. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,795
    50
    Vancouver
    Paul M
    Imperial measurements???
    illegal: no
    stupid: yes
  8. Brian W. Ralston
    Brian W. Ralston Supporting Actor
    Apr 4, 1999
    604
    Los Angeles, CA
    Brian W. Ralston
    Lance said...
    So....you are saying Canada is the "Jan Brady" of the measurement system? Always stuck in the middle?
    ......"All I ever hear is metric, Metric, METRIC! " [​IMG]
  9. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    That's strange. Your thermometers do not have both °F and °C? I think just about every thermometer I have ever seen has both. The only I've seen with one scale is in °F.
  10. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
    Though I would argue that for non-scientific purposes, Fahrenheit is superior to Celcius.
  11. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    It is not uncommon in Australia to ask for a two by four, a meter long. [​IMG]
  12. andrew markworthy
    Sep 30, 1999
    4,762
    12
    FWIW, Imperial measures are no longer legal in the UK (perverse, because that's the home of Imperial measures, of course). Although stores can still have signs saying how much something is per pound, per yard, or whatever, these are optional. However, signs in metric are mandatory.
    It's not the measures that are stupid, but the subdivisions. Most Imperial measures are based on recognisable human-based units (the yard is roughly an arm span, etc), whereas the metric measures are based on an entirely arbitrary fraction of the Earth's circumferance (and the French 'scientists' doing that measurement got it hopelessly wrong). Where the Imperial measures are dire is in the subdivisions - 12 inches to the foot, etc. In fairness to us Brits, we did think about changing this system some time ago (around 1800, I believe) making the subdivision metric (10 inches to the foot, that sort of thing). However, the scheme was felt to be too confusing and was abandoned.
  13. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    So how many Stone do you weigh?
    Get back to you in a fortnight[​IMG] [​IMG] [​IMG] [​IMG]
  14. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    That is a real short 2 x 4!
  15. PhillJones
    PhillJones Second Unit
    Jan 20, 2004
    472
    I remeber is a maths class at school being asked to work out the speed of light in furlongs per fortnight.
    In our defense, Stones are from the same measurement system that punds are from. It's you guys that make no sence by ignoring the larger units.
    The Metric Martyrs were the market traders who tested the law about metric measurements
    http://news.bbc.co.uk/1/hi/england/cornwall/3518289.stm
    Bunch of idiots. It's not like they were being forced not to use Imperial, they just wanted to refuse to use metric.
    Phill
