Image noise on Computer TV Output
Discussion in 'Archived Threads 2001-2004' started by Jean-Francois Masse, Apr 2, 2002.
  1. Jean-Francois Masse
    Oct 4, 2000
    45
    Today I decided to connect my computer to my receiver because I wanted to watch divx files on my 32" TV. I've tried two days ago to hook up my s-video out from my ATI Radeon VE to my Sony Mini DV with a 3 feets long cable to test the quality. I recorded different files and disconnected the cam. I went in the next room and connected my cam to my receiver and watched those images. It was truly better that I was expecting so I decided to buy a 15 feet cable to be able to connect directly the two components. Sadly the quality is not the same. there is some noise (2 wavy lines running across the screen vertically. One is lighting the picture and the other is darckening. My s-video cable is far from a Monster Cable and the 15 feets are maybe too long or is it someting else?
    I'm ready to buy a better cable but only if my chances are good.
    Any tips?
  2. Jim A. Banville
    Jim A. Banville Supporting Actor
    Jun 20, 1999
    630
    While the new cable may be defective, since the first "test" you did was via the camcorder and second was directly to the TV, you really can't count on that as an adequate quality test of one cable over the other. Most likely you are seeing a ground-loop problem. Are your components plugged up to the same outlet?
  3. Costas
    Costas Extra
    Jul 28, 1999
    23
    I noticed the same thing on my computer the first time I hooked up the S-video to my TV. I got rid of it by using a cheater plug on the computer power cable, as every other thing I tried didn't work. If you have a printer hooked up to the same PC, this will also create a ground-loop.
  4. Jean-Francois Masse
    Oct 4, 2000
    45
    thanks for the answers. I solved the problem by using a cheater plug on the computer power cable that cut the ground. It's maybe not the safest way to fix it but that does not cost a lot...
