Image cut while watching a widescreen movie on 4:3 TV
Discussion in 'Archived Threads 2001-2004' started by Thik Nongyow, Jul 9, 2002.
  1. Thik Nongyow
    Thik Nongyow Stunt Coordinator
    Jun 3, 2002
    189
    A few days ago, I watched the widescreen version of the movie "Shrek" and noticed that even though the picture is in widescreen format, some of the left and right parts (approx. 10% in total) of the picture are missing. I ran the movie on a 22" 4:3 analog TV set when this happened. The movie is in 1:78:1 anamorphic widescreen.
    When I ran "Shrek" on my DVD-ROM using PowerDVD, I noticed that all parts that are missing on my 4:3 TV do appear on my PC screen. It was interesting that while the movie's menus are in widescreen by running PowerDVD, they were in pan-and-scan on my TV screen. I wonder how can this be?
    I set up the DVD player correctly according to its instruction manual by setting the player to 4:3 letterbox, but from this some parts of the widescreen image are missing. Has it something to do with the width (22") of the TV set? Having an 4:3 instead of a 16:9 TV set? Or something which I am not aware of?
  2. DustinDavis
    DustinDavis Stunt Coordinator
    Dec 26, 1999
    171
    Could be too simple...but did you play the right disc? Remember that the 1.78:1 version is on Disc 2.
    Also, if only 10% of the movie is missing from the sides, this could be a result of overscan, which a PC will not have. Every TV has areas on the border of the set that are not visible, called overscan. 5% on each side is fairly common, and would account for what you saw.
  3. Thik Nongyow
    Jun 3, 2002
    189
    To answer your question, I did use Disc 2. Anyway, it must be overscan and I suggested 10% as I do not know how much of the image was lost on the TV screen. The approximation may be correct or incorrect.
    To let you know, the TV I use is a Sony Trinitron which was manufactured in 1997.
    Now, I wonder why the DVD menus in "Shrek" are missing about 40% of the image, but the movie is missing about 10%.
  4. Jesse Skeen
    Jesse Skeen Producer
    Apr 24, 1999
    4,355
    255
    4,110
    Most discs will tell the player to crop the menu screens if it's set to 4x3, even if you pick letterbox. Don't know why.
