I'm upgrading to DD 5.1, can I get some help?
Discussion in 'Archived Threads 2001-2004' started by NathanP, Oct 16, 2001.
  1. NathanP
    NathanP Supporting Actor
    Aug 13, 2001
    841
    Alright,
    I dunno what the heck happened to my last post, but I'll start another.
    I'm upgrading one of my secondary systems to full-fledged DD 5.1.
    Thing is it uses a 4 channel reciever that's not DD ready and I've been using a Pro-Logic processor with speaker inputs to get Pro-Logic out of it.
    Are there any DD 5.1 processors like that I can use (with rear and center channel inputs)?
    I've heard Yahmaha makes some like that.
    Thanks for your help!
    Nathan
    "Um, ER, uh, No, it's not a bedroom HT, I just love it so much, I sleep in it."
    "Okay look, the St. Louis Rams rule, everyone else sucks, so sit down and shutup!"
  2. Sean-D
    Sean-D Agent
    Oct 12, 2001
    42
    Nathan, is there a reason that you are holding on to this dinosaur? Any add-on processor you get is going to cost you money anyway. Do yourself a favor and go out and buy a cheap yamaha,onkyo or denon surround processor. I had the same problem as you about 6 months ago. I bought a denon reciever with dolby digital 5.1 and dts 5.1 from sears for about $280 to upgrade my pro-logic reciever that I had been using in my master bedroom. Problem solved. Sometimes it's just not worth holding onto older technology. Any other kind of patch work project that you use won't even sound as good as one of the new cheap recievers. Just my $.02
    Sean-D.
    "If at first you don't succeed...,remove all evidence that you ever tried."
    [Edited last by Sean-D on October 16, 2001 at 01:11 PM]
  3. NathanP
    Aug 13, 2001
    841
    Sean..
    I just don't feel like spending this amount of cash on a secondary system..
    Just something cheap..
    I bet I could get a processor cheap on ebay if someone names one!
    Nathan
  4. Michael Mathius
    Michael Mathius Screenwriter
    Nov 12, 2000
    1,487
    7
    110
    Nate i agree with Sean. Even on ebay you should be able to find a cheap 5.1 receiver. just my .02 cents
    Don't make me angry. You won't like me when I'm angry.
    [​IMG] 3EMS Hometheater
  5. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,989
    9
    110
    If you want to keep your existing DPL receiver and you further want to get 5.1 from the existing setup, then the only way it can be done is to use a processor from VANTAS. It's about 500.00 if it's still available. If you looking to simply upgrade to 5.1, you'll find a tone of stuff on EBAY and some will actually have DTS available. You can probably get one for around 100+ dollars.
    ONCE, I CONSIDERED SPARING YOUR RETCHED LITTLE PLANET CYBERTRON, NOW.., YOU SHALL WITNESS IT'S
    DISMEMBERMENT...
  6. NathanP
    Aug 13, 2001
    841
    Are there any other cheap decoders/processors that I can use in a reciever thats not 5.1 ready?
    Nathan
