Gary Thomas
- Jan 17, 1999
I've been battling an annoying ground loop problem caused by my satellite connection. Here's the background:
Dish satellite properly grounded, along with phone ground and house ground at 1 point on grounding rod.
RG6 cable from outside box to satellite receiver. When I disconnect the cable, the buzz goes away. When connected to satellite reciever, buzz is present even w/ unit turned off.
I have tried disconnecting every other plug, one at a time, with no effect on the buzz.
1/2 components plugged into a Panamax surge protector, other 1/2 into a Belkin surge protector. Both plugged into dedicated 20 amp outlet. I tried plugging the Belkin into the Panamax w/ just 1 plug going to the outlet...no effect on the buzz.
When satellite cable is run through the Belkin surge protector, 50% of buzz goes away.
I tried a Jenson ISO Max, but discovered it is not compatible with satellite.
No other grounds in house...with the exception of a plumbing ground - basically it is a 2' long ground wire connecting a pipe on either side of a valve.
I do have a Lutron dimmer in home theater room, but it is not on the HT outlet. It controls track and rope lighting on the ceiling & in a tray. The track lighting hums a bit when on, but is silent when off.
What am I missing??? Are there any ground loop eliminators for satellite? Any other ideas?
Thanks!
Equipment List:
Echostar Satellite Receiver
Panasonic DVD Player
Denon Receiver
Samson Amp
Behringer EQ
VCR
IR Repeater
Thanks!
Equipment List:
Denon Receiver
Samson Amp
Behringer EQ
VCR
IR Repeater
