I'm not too bright...plz help me choose
Discussion in 'Home Theater Projects' started by John*DB, Sep 13, 2004.
  1. John*DB
    John*DB Stunt Coordinator
    Jul 1, 2004
    85
    I posted this on the HT Basics board...don't know if it is more appropriate here.
    Okay. I am more confused the more I read. I need answers from people who KNOW about HT WELL!!
    I have ordered all the "stuff" for my first HT. The only thing left is the wires and interconnects. I have read all about "how to" set up the HT. I have read all the threads about my specific HT items (DVD player, projector, etc...)
    NOW,
    I need to get the junk to hook it all together and I want to do it right the first time!!!
    I know I want to use BlueJeansCable for my wiring. I have also read all their pages and I am still just as much confused.
    HERE IS WHAT I HAVE
    Help me put it together PLEEEEEEASE
    • Infocus 4805
    • Yamaha 5760
    • Denon 1910
    • JBL E series EC35, E20 x 4, E250 sub
    Now, you can see this is NOT high end. BUT it is QUITE good for my first system - thanks to all the input I have received so far from all of the fine people on the board.
    I want to use DVI. But what does the 4805 need? DVI-A, DVI-D, DVI-I???
    I want an XBox. I probably want to use component for that right?
    I know as far as audio goes - Coax is Coax. I know I don't need "specialized" subwoofer and digital audio cables. But I think thats how BlueJeans sells it.
    I know I am asking a lot here. I am asking for specific help for specific items that probably no one else will benefit from reading. But I don't know what will be the best and work with my system.
    Thanks for all input. I truly do appreciate it!
  2. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    I'm not familiar with your projector but MOST current AV equipment requires Single Link DVI-D cables. Dual link will work too but you don't need to spend extra for it and you don't get any benefit from it. I use the Parts Express Dayton cables for Component and regular RCA audio cables. I'm sure Blue Jeans is better but the PE stuff is a great value and I'm quite happy with it.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Can the Infocus take a progressive signal? If so, you must have one of the following to get the XBox to go into 480p or 720p mode:
    - The Microsoft Advanced AV Pack ($20)
    - The Monster Gamelink 400 X Component cable (~$50) and the MONSTER CABLE 100 X fiber optical cable add-on (~$35)
    The Microsoft product is cheap both in price and quality. I hate to shill for Monster, but their XBox cables are the only ones I know of that appear to be designed for progressive/HD video.
    The Monster component cable will give you L/R audio plugs. But to get true 5.1 sound, you need the stupid 100X fiber-optic add-on to provide the optical-digital signal.
    I got mine from someone on eBay.
