I'm not getting any on screen menus on my TV!
Discussion in 'Archived Threads 2001-2004' started by Michael Cook, Jan 8, 2002.
  1. Michael Cook
    Michael Cook Stunt Coordinator
    Dec 25, 2001
    238
    No menus from my receiver are showing up on the TV. It is a Wega and I am running an s-video from the tv to the tv/monitor on the receiver. Do I need to hook something else up to see the menus??
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    TV input selection correct?
  3. Michael Cook
    Dec 25, 2001
    238
    Yes, I have it set on Video 1 which is where the s-video is plugged in from the receiver.
  4. Ken Seeber
    Ken Seeber Supporting Actor
    Nov 5, 1999
    787
    2
    What receiver are you using?
  5. Michael Cook
    Dec 25, 2001
    238
    It's a Pioneer VSXD509-S. My father in law has that receiver and the menus show up on his TV, but he has an old TV and has to set the channel on the TV to 91.
  6. Paul_Dunlop
    Paul_Dunlop Second Unit
    Nov 28, 2001
    318
    Hi
    It could be that when you hook it to his TV, you're using the composite cable instead of S-VID. (since his TV is old)
    Try using a composite cable from your receiver to the TV to test it out.
    Hope this helps
    Paul
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    just to verify:
    1. you are running a s-vid cable from the "monitor out" on your receiver to the "video 1" input on your wega
    2. the wega is set to video 1
    if this is the case, you should definitely be getting the osd. the only thing i can think of is that your receiver does not pass the osd through the s-video.
    try connecting a composite cable instead and see if you get a picture.
  8. Andy Anderson
    Andy Anderson Second Unit
    Dec 11, 2001
    317
    That's definitely a possibility, Ted. My friend's Marantz 7200 is the same way. It's primarily an S-Video switcher, but it does have 1 or 2 Component inputs. The OSD is only passed over S-video or Composite.
