I'm looking for an effective electronic coin sorter. Any recommendations?
Discussion in 'Archived Threads 2001-2004' started by Don Black, Dec 29, 2002.
  1. Don Black
    Don Black Screenwriter
    Dec 11, 1998
    1,480
    Rather than give into CoinStar's insane 8%-10% fee, I'm looking for a well-built and effective motorized coin sorter. I look at it as a long-term investment that I will use for 3+ years. Does anyone have any recommendations? Thanks!
  2. HienN
    HienN Stunt Coordinator
    Jul 4, 2002
    144
  3. Carl Miller
    Carl Miller Screenwriter
    Mar 17, 2002
    1,461
    Commercial ones run several hundred dollars all the way into the thousands. If you're serious about getting a commercial machine, you might be able to find some used machines.
    A friend of mine uses a commercial one called a Jet Sort, don't know if that's the manufacturer or just the machine name. $900 a few years ago and he's been very happy with it.
    The ones from Hammacher, Sharper Image etc that run $20-$30 are crap. They take maybe 10-12 coins at a time, get stuck in the machine, coins end up in the wrong tube and clog it up etc, etc.
    Unless you're really set on a commercial machine, you'd be best off just getting a sorting tray set (just throw the coins on the tray and shake) and a set of cones.
