I'm almost done with my sub!
Discussion in 'Archived Threads 2001-2004' started by tom_furman, Sep 10, 2002.
  1. tom_furman
    tom_furman Stunt Coordinator
    Sep 6, 2000
    174
    Just waiting for the tempest to get dropped off at my door. Thank you all for the help. I decided to flush mount my amp like Warrick and I'm proud to say that it looks great sitting in there. a MUCH cleaner look. I'll have pics up soon so that they might help someone else with their sub.
    Here's one tip that I havent seen anyone else do (althoguh I bet it has been done)When I was planning out my port figurations I has doubts about how good a paper port could stick with epoxy to the MDF. Most people bu the port holes to the inside dimension of their port and just butt the port up against the MDF plug and epoxy it. SOOO..I cut the hole in the MDF plug to the outside of the port, and the hole in the encap to the inside of the port. that way the port would have 3/4" all around to epoxy to, yer when you look down the encap it is still a nice straight hole throguh the port.
    I hope that made sense! if not i'll explain it better
    Now 2 questions. Does the fluff (polyester badding) inside the sonotube have to be smooth, or can it have slight wrinkles? I tried to get it as flat as possible though.
    What is the cutout size for a Tempest? I couldnt find it anywhere and want the holes cut so I can pop it in when it gets here.
    Thanks, tom
  2. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Tom,
    That's the same way that I do ports when I use straight pipe! Works good!
    Also, I think the Tempest cutout is 14", but don't know that for sure.
    Brian
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    That's how Sunosub II's 6" PVC pipe is attached (though not with epoxy).
    One other tip: please proofread your posts. I still haven't figured out what some words mean in that initial post.
  4. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    Pat has the port info on his site. It's a great idea to secure it. Also, the tempest cutout is a little smaller than 14" if I remember right. Do you have the Jasper Jig and a 1/4" spiral bit? If so, I can look for the exact setting for the tempest.
    Edit: Found this but I didn't record the exact setting with the Dewalt/Jasper/1/4" bit. I thought I did... maybe it's on paper at home if I can find it.
    http://www.hometheaterforum.com/htfo...ghlight=cutout
  5. Mark Fitzsimmons
    Mark Fitzsimmons Supporting Actor
    Aug 18, 2001
    539
    I cut 13 7/8" for my tempest.
  6. Casey H
    Casey H Stunt Coordinator
    Jul 29, 2001
    66
    I second Mark's dimension for the Tempest cutout!
  7. Patrick Sun
    Jun 30, 1999
    38,717
    463
    You wouldn't think 1/8" makes a difference, but it does for a driver cutout!
