If your subwoofer has a L/R input, read this!
Discussion in 'Speakers & Subwoofers' started by MuneebM, Jun 9, 2004.
  1. MuneebM
    MuneebM Supporting Actor
    Jan 12, 2004
    621
    If:
    (1) You use the mono subwoofer pre-out from your AVR
    AND
    (2) Your subwoofer has left & right inputs
    Split the single cable coming in to the sub so that you are plugged in to both the left and right input terminals, and you'll actually gain 3-6 dB SPL output from the sub, giving you significantly more headroom or allowing you to turn down the gain on your subwoofer to achieve ref level SPLs.
    I tried this on my Dayton STF-2 (modded Dayton from partsexpress) and I actually gained 5-6 dB SPL output, which allowed me to turn down the gain of the Dayton's amp significantly [​IMG]
    http://66.46.69.23/sigserv/pl/index.pl?p=1
    My DVD Collection
  2. MingL
    MingL Stunt Coordinator
    Mar 26, 2003
    214
    I don't think we will gain 3-6dB of headroom by using both L&R inputs.
    Headroom is generally fixed for any sub. So by doing what you just did, you compensated for the increase of signal level from 2 inputs by turning down the gain knob from the otherwise convnetional method (Ironically, the gain knob should be called an attenuation knob to be describe its function accurately )
    It would be the same as sending just a mono signal and pumping up the gain by the same amount. I doubt headroom has increased.
  3. JohnSmith
    JohnSmith Supporting Actor
    Apr 8, 2003
    554
    Welcome to last year!
  4. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    The max output on the sub stays the same, of course. It can allow the receiver's sub-out to be lowered, which may have benefits.
  5. Cam McFarland
    Cam McFarland Supporting Actor
    Feb 6, 2004
    699
    Ya know, a guy comes on line to share something &
    gets slammed for it......says alot. [​IMG]
    We neophytes get "excited" when we learn stuff, be it
    for me stereo's, or others maybe motorcycles or
    whatever it might be, & we like to share.
  6. Jack Gilvey
    Mar 13, 1999
    4,948
    ...and if it's wrong, it needs to be corrected.
  7. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    This isn't to say this bit of info isn't useful, but if people took the time and searched first, they would realize some topics have had extensive coverage before.
    It does say alot that people are so lazy as to not even look at past topics to see if they might gleen any insight first, and then provide a new spin.
  8. Cam McFarland
    Feb 6, 2004
    699
    Yes.....that is absolutely correct.
    And it can be handled the way you did Jack, or the way
    John did.
    Sorry guys, I just have always been more of a speed freak & gun nut. Never messed with stereos other than in my cars or trucks.
  9. Cam McFarland
    Feb 6, 2004
    699
    deleted
  10. MuneebM
    Jan 12, 2004
    621
    I know this might be old news to some, but to others that have L/R inputs on their subs (Paradigm and Dayton sub owners come to mind), they may not know it. I wanted to post this thread up for those that are unaware of it and give them a heads-up.
    I had no idea this would give me a gain on my sub, so why the heck would I go searching the forum for it??? This applies to others that don't know about this, they won't go searching for it, but if they see this thread fresh and new, then they'll pick up on it and try the same on their subs.
    A forum is for sharing ideas, if you don't like the thread or if you think its already been discussed and not worth your time then just skip it, simple as that. No need to be anal about it! [​IMG]
    http://66.46.69.23/sigserv/pl/index.pl?p=10
    My DVD Collection
  11. MuneebM
    Jan 12, 2004
    621
    Ok, I may have said the wrong thing. I realize I didn't gain any headroom, but by splitting the signal into L&R I gained 5-6 dB at the same gain on my sub's amp. I, of course, recalibrated my sub to REF level, and had to turn down the gain on the sub's amp. The point is, I'm now running the gain on my sub lower, and this trick can also allow for the receiver's sub-out to be lowered as Jack mentioned.
    http://66.46.69.23/sigserv/pl/index.pl?p=11
    My DVD Collection
  12. Jack Gilvey
    Mar 13, 1999
    4,948
    This is the main benefit, as many sub-outs can run into substantial distortion as the gain increases. I run mine as low as it'll go and just up the gain on my plate amp.
    P.s. If you're actually getting reference level out of your "modded Dayton" at anything under 40Hz...I need to know what the hell mod you did! [​IMG]
  13. Kevin G.
    Kevin G. Second Unit
    Sep 30, 2003
    403
    soooo...
    Via a y-cable? or a splitter of some sort (what if you have RG-6 cabled down to RCA adapters as it is?)
    Just checking guys, I had no idea, and I applaud Muneebm for sharing.
    Thanks dude,
  14. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    It can also help with a insensitive auto function.
    Don't worry MuneebM. Most of the Threads posted have all been discussed at some time or another. I rather enjoyed your new discovery for what it's worth, even though it needed a little tweaking.
  15. MuneebM
    Jan 12, 2004
    621
  16. MuneebM
    Jan 12, 2004
    621
    Well, I meant I re-calibrated the Dayton to reference level using DVE and my SPL meter. I'm using the Dayton as a secondary/rear sub, my primary/front sub is an HSU STF-2, so I haven't really measured the peak SPL of the modded Dayton below 40 Hz. The mod I did was simple, I replaced the stock 10" driver with an HSU STF-2 10" driver and it made a big improvement: cleaner and tighter bass, and now it definitely goes a lot lower than it did stock.
    Actually, I'm thinking of sticking the stock driver back in and taking measurements at various frequencies and then putting the STF-2 driver and re-measuring to give numerical proof of the improvement. Of course, that's a topic for another thread, so I won't go off-course.
    http://66.46.69.23/sigserv/pl/index.pl?p=16
    My DVD Collection
  17. Kevin G.
    Sep 30, 2003
    403
    aren't we, then, degrading the signal and, therefore, defeating the purpose of using the RG-6 in the first place?
  18. MuneebM
    Jan 12, 2004
    621
  19. Kevin G.
    Sep 30, 2003
    403
    Another thought has entered my skull...
    How are you running the second sub...do you have a receiver with two LFE outputs? Or are you running a y-splitter to begin with? you already mentioned you are running RG-6, so you arent running the high pass side and rears off the sub... soooo...?
  20. MuneebM
    Jan 12, 2004
    621
