If you are using the digital output on your cd player is it....
Discussion in 'Archived Threads 2001-2004' started by anthony_b, Sep 8, 2001.
  1. anthony_b
    anthony_b Screenwriter
    Aug 18, 2000
    1,077
    4
    110
    If you are using the digital output on your cd player will it sound only as good as the digital circuit in your reciever ?...Can I make a low end player sound great on my high end receiver ?
  2. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    My personal opinion is that if you use the digital out on your CD player, it's going to sound about as good as it can sound. I'm sure many may disagree, but I'd say you're in a better spot than having a high-end CD transport and a lower end, budget receiver.
  3. Elbert Lee
    Elbert Lee Supporting Actor
    May 24, 2000
    501
    Anthony - I made a comment on this from your other post.
    I second the reco on getting a cheaper transport if you have or are planning on getting a good preamp or receiver.
    Elbert
  4. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
  5. Roger Kaufmann
    Roger Kaufmann Stunt Coordinator
    Dec 27, 2000
    119
    ANY system is limited by it's weakest component. It doesn't really matter if the weak link is the CD player, the receiver, the CD itself, speakers, amp etc. If you are using the digital output from your CD player to your receiver then you will be using the DAC from the receiver. As long as the receiver's DAC are superior to the CD player's then your sound should improve using the digital connection.
    R. Kaufmann
    My DVD Profiler Collection
  6. anthony_b
    Aug 18, 2000
    1,077
    4
    110
    How would I know if the DAC on my receiver is better than my CD player ?
  7. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    Test it and see. That's all you can really do as to a certain extent this may be a matter of personal opinion. You could also possibly be able to find out by researching your components and finding out what DACs they use.
    Also there's the other issue of what happens with the analog inputs on your receiver. Many receivers don't have analog pass through, so your analog signals will be converted to digital before going through another set of DACs and then on to the amp. This will definitely be happening if you are using any DSP modes on your receiver. But if you pass the receiver a digital signal, you'll be reducing the number of conversions the sound goes through, which is almost always a good thing.
    List your components, or those that you are considering, and perhaps some people can give you insight into those.
  8. Thomas_A
    Thomas_A Second Unit
    Feb 2, 2001
    398
