If I were to upgrade from the LSi.... what should I get?
Discussion in 'Speakers' started by Joey_V, Jun 11, 2005.
  1. Joey_V
    Joey_V Second Unit
    Apr 13, 2004
    354
    I'm actually having a little difficulty searching for the possible "next" speaker. Lets say between 1000-1500$ is my budget for a pair of good speakers. I prefer bookshelves since I need to move them around from my apartment to the home.
    Give me ideas of which speakers I should look out for. I have LSi9 (and LSi7 for rears) for mains right now.
    I have an SVS PC+ subwoofer to anchor the low end.
    Thanks!
    Joey
  2. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    Honestly, you will have a hell of a project on your hands to get a big improvement in sound as what would have is already awesome.
    What do you have driving them? That might be the first step.
    If not, just get:
    [​IMG]
    This:
    And be done with it...forever [​IMG]
    Seriously, your speakers would probably benefit from a very good pre/pro/amp combo.
  3. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Let's just say I would never replace my LSIs with those Klipshes.
    To me the only better choice in that price level would be a pair of Magnepan 1.6 QR but they are at $1699. Can get em cheaper on the used market though.
  4. Joey_V
    Joey_V Second Unit
    Apr 13, 2004
    354
    What about the Onix Reference 1 or the perhaps the SOnus Faber Concerinos? I could possibly fit into the budget the Concertos.
  5. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    NHT. Not a lot more money (if any), but definitely an upgrade. The M6 monitor part (top portion) of the T6 tower system just caused the T6 to get a class A rating from Stereophile. They are listed $600 each, and can be found even cheaper.
  6. VinhT
    VinhT Second Unit
    Feb 14, 2002
    357
    For a stand-mounted speaker in that fairly wide price range, my recommendation is the B&W 705. It will be a significant improvement. However, the 705 is a tad lean when it comes to upper-bass output, so depending on how you like your bass tuning, the 705s may not be right for you.
  7. Joey_V
    Joey_V Second Unit
    Apr 13, 2004
    354
    What about the Onix Reference 1? Those seem to be along the level of the LSi9 - it should be an interesting matchup.
    Anyone agree? Anyone here recommend the Ref 1s?
  8. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I like the NHTs a lot. IMO, they're easily better in the midrange. The highs are a bit brighter, but overall, I'd probably choose the M6.
    If you push the budget just a bit, I'd go listen to the Joseph Audio RM7Si Signatures. Surprisingly, a lot of bass and a midrange that is so clear it's not even funny. Very smooth, clear highs just like the LSis.
    Next, I'd say look at some kits like the GR Research A/V-1 or A/V-2 or Adire Kit 61 or Kit LCR.
  9. Lewis Besze
    Jul 28, 1999
    3,134
    I've yet to hear any NHTS that I liked, I haven't heard this one though, so who knows....
  10. Joey_V
    Joey_V Second Unit
    Apr 13, 2004
    354
    Thanks for your insight Lewis!
    Keep 'em coming guys! [​IMG]
  11. Steve_D
    Steve_D Second Unit
    Nov 28, 1999
    299
    If you like those Lsi's, I agree it will be tough. The Studio 40 comes to mind because its my all time favorite reasonable monitor. If you like a Dynaudio like sound, ACI Sapphires may be your thing.
    I agree with the other guy, your $1500 may be better spent on something else.
