If I have To Replace My RPTV How Is The Toshiba 50" Widescreen?
Discussion in 'Archived Threads 2001-2004' started by SteveMo, Aug 5, 2002.
  1. SteveMo
    SteveMo Stunt Coordinator
    Jun 19, 2002
    116
    MY CURRENT SITUATION
    We are trying to fix my current televison but are having difficulty. If I get a new one I am looking at this Tohsiba 50H82 RPTV. I just want to be sure of a few things. This is just a what if but it is pretty likely since my Tech could not fix the convergance right. My auto focus feature now reads " No Sensor Data". He is going to learn more about the problem and may fix it but if not...
    Tohsiba 50H82
    1. It does not upcovert a 480P signal
    2. It does not have a reflective case that would produce glare inside the set causing what most describe as shadows.
    3. I could sit 6 to 7 feet from it and be satisfied with the overall image and uniform luminence.
    Questions:
    1. Who owns one of these and likes it?
    2. Who owns one and does not like it?
    3. Is the Velocity Scan Modulation an issue?
    Thank you for reading and I appreciate your help.
    Also are there any ISF Technitions that could do a visit to Columbia in Missouri? If so when and what are your rates?
  2. SteveMo
    Jun 19, 2002
    116
    I want to keep the one I already have and I don't think that the problem is normal. I hope they can fix it.
    Samsung looks great besides the small problem [​IMG]
  3. SteveMo
    Jun 19, 2002
    116
    Darn it does the up conversion
  4. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    The upconversion isn't much of an issue. I certainly wouldn't pass up a good set because of it.
    Also, the 50H82 does a better job of it than its predecessor such as my 42H81, which I love. Read Michael TLV's updated report for more info.
    Velocity Scan Modulation is easily bypassed. It's not on, by default, in the "film" mode; go to this mode, adjust the settings (contrast, tint, etc.) to your liking, and they will all be saved in the "preference" mode...including VSM being off.
    Cheers,
    Jan
