Brett Loomis
- May 9, 2001
Ok , I think I am almost ready to kick off this project. I just want to confirm a few things.
Are the following all the correct dimensions/cut sizes I need to build the 214L Adire alignment?
Top & Bottom = 22" x 22"
2 sides = 22" x 32"
2 sides = 20 1/2" x 32"
Brace A = 32" x 9 7/8 with notch cutout at 2 5/8" and 24 3/4" (2 pieces)
Brace B = 20 1/2" x 32" with notch cutout at 5 1/8" and 24 3/4" ( 1 piece)
How accurate do my cuts have to be?
Any suggestions when cutting these pieces?
Can anyone send me some links or detailed instructions on the order and process of assembly/gluing/caulking/screwing of these pieces?
Best amp for this sub?
What type of screws and length for best results?
I appreciate any and all pitfalls I should avoid.
Thanks, Brett
2 sides = 22" x 32"
Thanks, Brett
