If i am a registered user, how can i get myself a signature? (1 Viewer)
Jack Briggs
Oscar:
First you need to find a small image file you like. The 'net is a big, big place, so you should be able to find one to your liking. But keep it small.
Then, go into your user set-up file and key in the URL in the section labelled "signature."
Submit it, and then you're good to go.
If you want to tinker with it or make sure it's working, try working on it in the "Testing" forum.
Hope this helps.
JB
Parker Clack
Schizophrenic Man
Kansas City, MO
Parker
Oscar:
Like Jack grab an image that you want and then go to the User Control Panel > Edit Profile and put in the link to your picture in there. If you don't have a picture to use and just want to put in some text this is where you would put that too.
Parker
Oscar W
Oscar
Hey! It's another Oscar out here in the wild west of El Paso of all places! :emoji_thumbsup: Howdy Oscar!
~oscar
(near Mesa & Festival)
Oscar
Hello, but you can call me Antonio since its my second name to avoid confusion.
MJL
