If designing a couple of twin subs, how much would adding a plate amp affect?
Discussion in 'Archived Threads 2001-2004' started by Javier_Huerta, Jan 16, 2003.
  1. Javier_Huerta
    Javier_Huerta Supporting Actor
    Mar 9, 2002
    619
    Hi!
    I was wondering, let's say I have a pair of identical subs. But I add a plate amp to one of them (in typical "slave-master" fashion).
    How much would sound be affected because of the change in internal volume? Would it be negligible? Can I still use both subwoofers side by side and expect good results if all internal dimensions and porting are the same?
    I'm confused about this... [​IMG]
  2. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Javier,
    The differences in volume, and therefore sound, should be negligible.
