1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
IE Problem
Discussion in 'Archived Threads 2001-2004' started by Aaron Copeland, Feb 15, 2003.
  1. Aaron Copeland
    Aaron Copeland Second Unit
    Nov 3, 2000
    445
    Aaron
    Anytime I open a non-maximized Internet Explorer window the window is messed up. You can see a picture here: IE Window
    In the picture you can see one window maximized and a screwed up second window where only part of the title bar is visible. I can use my mouse to click and drag the window to a larger size at which point it does look normal. The problem is that as soon as I shut all of the IE windows and then start the browser back up again, the problem comes back. Where do you go to change the default window size of a program?
    Aaron
  2. John Watson
    John Watson Screenwriter
    Jul 14, 2002
    1,937
    Does shutting down and restarting restore better settings for you?
    It sometimes helps me.
  3. dave_brogli
    dave_brogli Screenwriter
    Mar 30, 2002
    1,021
    I always had have luck with just dragging to maximize it. Then my comp always "remebered"
