Identifying JP DTS
Discussion in 'Archived Threads 2001-2004' started by Elliott Willschick, Nov 28, 2001.
  1. Elliott Willschick
    Elliott Willschick Second Unit
    Dec 1, 1998
    333
    I am very familiar with how to identify the new Jurassic Park DTS disc. However I bought it today and I looked at the disc and there is neither D2R1 or D2R2. My store has not had them in for awhile so I took the chance when I finally saw them. It sounds quite good but without the old one I can't compare it. Any help would be appreciated.
    Elliott
  2. Jakob_S
    Jakob_S Stunt Coordinator
    Nov 23, 2001
    59
    you have to look very carefully around the hole in the middle on the disc. There are a lot of codes/numbers - so try to look again, they should be there.
  3. Noel Sequeira
    Noel Sequeira Auditioning
    Jul 6, 1999
    10
    You have to check the status grid at the bottom of the back of the box. If it is red, you have the new version.
    You're right in saying the new pressings neither have D2R1 or D2R2 on the innner-hub.
    Also, you can insert the DVD into a DVD-ROM drive and open the VIDEO_TS folder. If the file dates say November 2000, then you have the new version.
    Noel.
  4. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
  5. Jakob_S
    Nov 23, 2001
    59
  6. Elliott Willschick
    Dec 1, 1998
    333
    Thanks to everyone who responded so quickly. I am positive that the ring has no code. I have tried three copies before I bought them over the past year and I found the D2R1 with no problem.
    I did manage to get a dvd-rom drive and confirmed the date is NOV 2000 so luckily it is the corrected one. Now that I got more time with I can notice the difference.
    P.S. I am sorry I had to start another JP thread :b
