Ideas on enlarging driver opening?
Discussion in 'Archived Threads 2001-2004' started by Geoff L, Jun 13, 2001.
  1. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Changing drivers and opening is allready 11 and 1/8 inch. Need to trim another 1/16 inch for an opening 11 and 1/4. Any ideas how I might do this to get a clean even cut? A jig saw would work but good control trimming this tiny amount is tricky! I prefer a nice clean tight fit. [​IMG]
  2. BrianW
    BrianW Cinematographer
    Jan 30, 1999
    2,563
    38
    Brian
    Using a router and a 1/16” rabbeting bit, cut a rabbet half the thickness of the driver plate. Then flip the driver plate over and use a flush-trim bit to hog out the rest of the wood on the other half by riding the flush-trim bit’s bearing against the rabbet. If you don’t have access to the both sides of the driver plate, then you’ll need to find a flush-trim bit with the bearing on top of the cutter (toward the shaft) rather than on the bottom
  3. Brett_A
    Brett_A Stunt Coordinator
    Dec 18, 2000
    109
    Use a dremel. 1/16" isn't that much, jsut take a light coat off the inside.
    Brett
  4. Geoff L
    Dec 9, 2000
    1,693
    Thanks for the ideas guys.
    Job is finished. Went with the router on the top half and used a rat tail file to finish the bottem, worked great...
