GregSanders
Grip
- Nov 2, 2002
I'm new to IB setups and really speaker building in general; however, my first project is underway. I'm building a 5.1 setup and am now working on the subwoofer. My budget is $350-$400 max, and I was decided on a Tempest in a sealed box with the 250W parts express plate amp, until I heard about IB. I have a size constraint of 19"Lx22"Wx30"H if I'm using a box.
People seem to be using a lot of drivers in IB setups, so I'm wondering if this is a function of IB setups needing more displacement or just people being nuts and excessive over bass (ie 4 Tempests or 12 Shivas, or even 2 Tempests). The room in which the setup will go is fairly small (I don't have measurements here), and I was previously under the impression that a sealed Tempest would put out more than enough bass.
With my budget, space constraints, etc, do you recommend IB or sealed with one Tempest?
Thanks in advance,
Greg
Thanks in advance,
Greg
