I want a SVS but sheesh!!
Discussion in 'Archived Threads 2001-2004' started by LaMarcus, Feb 12, 2003.
  1. LaMarcus
    LaMarcus Screenwriter
    Mar 7, 2002
    1,619
    LaMarcus
    I just spent a nice sum of money on a variety of things for my family, furniture and house repairs. Of course I had to get some HT for me too, a whole new system (speakers/ receiver).
    Now from another thread of mine I've discovered that I need a better sub. I really really really want to get a SVS but, sheesh man![​IMG] They're a lil expensive for my pockets right now, because of all the other stuff I bought.
    So, I want a sub as close to their performance as possible. Willing to spend $500 tops, and that's sneaking behind my womans back to get it. Waiting I could get a SVS, but when that upgrade bug bites, you have to do what it says, and it says NOW!
    So please help. Thanks.
  2. Jeffrey Forner
    Jeffrey Forner Screenwriter
    Jun 19, 1999
    1,117
    110
    If you want one so bad, wait. It will be worth it.
    There's my advice. Take it or leave it.
  3. LaMarcus
    Mar 7, 2002
    1,619
    LaMarcus
    I feel ya man, I'm just terrible at having patience
  4. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    What's the point of having such a powerful sub, anyway?
    [​IMG] [​IMG]
  5. Martice
    Martice Screenwriter
    Jan 20, 2001
    1,077
    Give these guys a shot.
    Acoustic-Visions
    Also I know a couple guys who also build subs on this site that would be glad to build you one. Go on over to the DIY section and take a sniff at what they have cooking over there.
    You can e-mail me if you want a few names of folks that have an archive of subs and speakers that they've made and would be glad to build a sub to your specs.
    Good Luck
  6. LaMarcus
    Mar 7, 2002
    1,619
    LaMarcus
    Thanks Martice, I'll give a looksy.
  7. Chuck Bogie
    Chuck Bogie Second Unit
    Jan 14, 2003
    397
    Suggestion - get the passive SVS, and run it either off an old receiver, or get one of those $125 or so 250 watt plate amps from Parts Express, until you can get a higher powered one.
  8. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    You mention house repairs. Do you have some tools (or access to) and some basic wood working skills.
    If you can build a box, or even just route some cirles in MDF you can build one hell of a sub for well under $500. I'm talking SVS Ultra performance for a little over $400 if a rather large enclosure and buiding your own enclosure doesn't scare you.
  9. Phil Mays
    Phil Mays Second Unit
    May 20, 2002
    361
    Just a thought. Klipsch Synergy subs are priced right at the moment. Quite frankly my KSW-15 has more bass than I will ever use. I also had the KSW-12 that I liked a little better and it had more bass than I could use. I've never heard the KSW-10 but our local dealor has them for $300.
  10. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Watch for a used CS - 2 for $150 each yesterday in the HWFS forum!
    If I wasn't so happy with my SVS driver DIY, I'd have bought one.
  11. Brian Fellmeth
    Jul 30, 2000
    789
  12. Ian Montgomerie
    Ian Montgomerie Stunt Coordinator
    Feb 2, 2002
    112
    The smaller PC-i subs start at 550 + shipping new, 500 + shipping if you can find the "B-stock" on their site. It's the upper end of your range, but it should fit.
  13. george king
    george king Supporting Actor
    May 29, 1999
    625
    Also, check out Brian at http://www.rutledgeaudiodesign.com/
    For $500 he can probably build you a better looking sub that sounds just as good. Besides Brian is a great guy to deal with.[​IMG]
  14. Bry_DD
    Bry_DD Second Unit
    Dec 29, 2000
    340
    This is what I did when I didn't have enough for a PCI. First I had a old Pro-logic rec then I bought the plate amp from PE.
  15. Jim_F
    Jim_F Screenwriter
    May 15, 2000
    1,077
    Hsu VTF-2. Had one. Loved it. It took an SVS 20-39PC to supplant it.
  16. LaMarcus
    Mar 7, 2002
    1,619
    LaMarcus
    I bought a amp online from parts express for $119. Going to use my 15" competition sub that's in a 4ft long bass tube and see what it sounds like...(for now).
  17. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    What would that "competition" 15 inch driver be? T/S for it? What are the specifics of that tube enclosure?
  18. Lon
    Lon Extra
    Jan 31, 2003
    20
    Actually I found the Klipsch ksw-12 to be boomy and had poor extension. Aftering firing up my svs ultra, I began to wonder how I ever thought the ksw-12 sounded good.
  19. LaMarcus
    Mar 7, 2002
    1,619
    LaMarcus
    Well the name of the drive is Aria. They're motto is "deep bass less space", it was originally purchased a a car subwoofer. Was the hardest hitting sub they had in the store when purchased. The woofer was so strong that the guy had it in a box and stood on it!
    Supposed to go down to 20hz. The tube is approx. 4' long, and it's not ported. What T/S means, I have no idea.[​IMG] [​IMG]
  20. ColinM
    Dec 9, 2001
    2,050
    TS = Theil / Small parameters - the electro-mechanical stats for the driver. (Qes, Xmax, etc.)
    Knowing these lets you use all that software to make the best box, or at least see what it sounds like on paper in the box you have.
