i want 2 rear centers with denon avr2802, do i need a specific amp?
Discussion in 'Archived Threads 2001-2004' started by felix_suwarno, Jul 7, 2002.
  1. felix_suwarno
    felix_suwarno Screenwriter
    Dec 2, 2001
    1,523
    receiver is denon avr2802. i have a pair of psb image 1b for rear centers. what do i need in order to connect the receiver and the image 1bs? any specific amp?
    thanks
  2. Peter Overduin
    Peter Overduin Supporting Actor
    Jun 30, 1997
    776
    No, you can use any receiver, even an old Dolby one, You don't need an amp. Connect to the pre-out on the 2802
  3. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    You don't need an extra amp. You can wire the speakers in series on the 2802 with no problems.
  4. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    Any amp or receiver would do by using the pre-outs on the 2802. But if you haven't purchased the 2802 yet, you could always buy the 3802 for $699 at 6ave.com and then wouldn't have to worry about buying any more amps since the 3802 has 7 channels of amplification.
  5. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    Felix, you don't need to use an extra amp or receiver. You can simply wire the speakers in series or you can wire them in parallel too. It'll just present a lower resistance to the rear channel amp and make it work a little harder but if you don't listen at ear splitting levels, it'll probably be fine. If you're the cautious type, then just wire them in series to be on the safe side.
    cheers,
    --tom
  6. felix_suwarno
    Dec 2, 2001
    1,523
    what is the meaning of wiring the speakers in series? sorry i am a newbie.
    i already have the denon. i chose it because i had a plan to upgrade to 7 channel amp, but at this point i dont have money yet.
    thanks for the response.
  7. Holger
    Holger Stunt Coordinator
    May 29, 2002
    87
    felix,
    just connect your speakers to the amp as follows:
    AMP(+) to BACKSPEAKER 1(+)
    BACKSPEAKER 1(-) to BACKSPEAKER 2(+)
    BACKSPEAKER 2(-) to AMP(-)
    regards, holger
  8. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    Holger's directions are for a "series" configuration.
    Parallel is:
    (2) wires connected to the Amp + terminal, one of them wires to each EX/ES speaker + terminal.
    (2) wires connected to the Amp - terminal, one of them wires to each EX/ES speaker - terminal.
