I took the X 1 plunge, any tips...? (1 Viewer)
todbnla
Todd
I decided to go for the Dell X1 $799.10 (after rebate) shipped price and it should be here Wednesday. Any suggestions for the initial setup? Other than what comes with it what else will I need (Of course a screen..) as far as cables, etc.
Not sure how this is going to work out as we have a ceiling fan in the middle of our living room, may have to work around this if possible.
BTW-Anyone use a Carada screen with this unit, if so, your thoughts on it...?
Matthew-K
If you plan on using it with a Progressive scan DVD player you might wnat to pick up a component to vga adapter. Also, make sure you check out the "faq" in the link above. It has everything you need to know.
Matthew-K
spirittoo
