Quinton
- Aug 18, 2002
Well I went and bought the Pioneer DV-250 from walmart. I'm probably going to end up being a semi-DIYer, so I need some help.
The home entertainment center I am building houses 2 15" subs, and I was looking at the partsexpress 250w plate amp to power these. What would be a good budget reciever to get to be able to hook up the plate amp plus 5 other speakers for surround sound. Can someone suggest a descent set of speakers to use for surround sound. Im looking to spend 300 or less for the receiver and around 200 or less for the surround speakers. I need something that I can easily connect the DV-250 to for surround sound and good SQ while listening to CD's. Thanks. If you need any more info, just ask.
Quinton.
Quinton.
