I need some advice..
Discussion in 'Archived Threads 2001-2004' started by Chris_MJ, Sep 19, 2002.
  1. Chris_MJ
    Chris_MJ Agent
    Apr 29, 2002
    33
    I am having a calibration done on Monday and I have the option of having the protective screen removed. I have a Toshiba 50H82. My question is what are the advantages and disadvantages? Will the image be greatly improved? has anyone had this done?
  2. Manuel Parrado
    Manuel Parrado Stunt Coordinator
    Jan 7, 2001
    119
    I have a RPTV with protective screen.
    In my case, I need it because I have little children.
    If you have none, you might consider removing it because contrast will be better. You see the way you have it right now, part of the light that leaves the screen is reflections on the prot screen from ambient lighting.
    If you remove it, all the light will come from the CRT's and contrast will be better overall.
    On the other hand, the screen provides protection against scratches and is easier to clean.
    If you don't anticipate children for a long while and think there is little likelyhood of braking the lenticular screen or scratching, then remove the prot screen. Otherwise, leave it on.
  3. Jimmy vb
    Jimmy vb Stunt Coordinator
    Aug 26, 2002
    54
    I would remove it unless you have children or animals that threaten it--or you have wild parties that subject it to beer and salsa being hurled at it.
