John-Miles
- Nov 29, 2001
Ok I have been having some problems with my reciever. It is a Sony STR-DE445 I know its not the best of recievers out there but im pretty sure i should be getting better performance. first of all my rear right channel went out. I checked all the connections, and switched out speakers (PSB alpha intro LR for my front and rear the CLR for my center) all the speakers are working, but no sound from the RR. this included when i used the test tone. i then checked the run of cable for any visible problems and came up with nothing.
my assumption then was it was a problem with my reciever, so i was just waiting for a chance to get it fixed. it was then that i thought i heard sound from my rear right I unhooked all my other speakers and sure enough there was now sound from the RR. i have since played music (FYI a DTS 5.1 cd The Police) I let this run for a few hours at a high volume. I now get good volume out of all my speakers, however i get very noticable distortion at at a volume of 17 (range is Min, 1-30, Max) at a volume of 24 the entire sound is crap, it becomes totally unlistenable, and to be honest I dont believe i should have a reciever that craps out just over the mid range volume.
if anyone has any advice on what the problem may be is this normal for this reciever or is it a bad one from the factory. it still has 2 years on the warranty, what should i do? all advice would be appreciated.
