I Need Help Quick With My Svs!!!!!!
Discussion in 'Archived Threads 2001-2004' started by Mark Guidry, Mar 12, 2002.
  1. Mark Guidry
    Mark Guidry Stunt Coordinator
    Dec 28, 2001
    222
    I just got finished hooking up every thing (S/1000 dual 39+)and when I tried to listen to the SVS's all I get is a loud buzz!! I also get a buzz through the center chanel only! Music is playing through the center but so is the buzz. If I turn the volum all the way down the buzz stops on both the center and the subs...also if you turn up the volum all the way the buz does not change...it stays the same volum the whole time. It doesnt matter if the ONKYO is on CD, VIDIO, DVD nothing...just BUZZZZZZZZZZZZZZZZZZ!!!
    SOMEONE HELP!!!
  2. Mark Guidry
    Dec 28, 2001
    222
    Never mind...I needed a damn cheater plug...I didnt think the buz would be that loud witout that...O well back to setting it up!
  3. Mark Guidry
    Dec 28, 2001
    222
    I tell you what...the buzz was way louder than I thought it could be...thats why I was unsure of what was going on...also it was comming out my center chanel as well...verry odd but that plug worked wonders!! I LOVE them [​IMG]
