TonyMarchioni
- Jan 31, 2002
To all,
First off, thanks for taking the time to look and to read this. Any help is greatly appreciated and I thank you in advance for all your help.
Here is my setup:
1) 50 inch wide screen digital projection tv from Toshiba
2) Dishnetwork 3900 receiver
3) Sony de675 receiver
4) Xbox (for game playing and DVD playback)
The Xbox is hooked up using component video and optical cable for audio into the receiver.
The dishnetwork is hooked up using s video and into the receiver using standard rca audio cables from monster.
All cables are from monster as a matter of fact.
Here is the problem...
When playing a xbox game with my son, the picture and audio is perfect.
When watching a dvd with the xbox, playback is fine UNTIL the receiver audio is higher than 25...at the 25 level, the picture gets back lines that appear when people on screen are talking...and only when talking....
BUT-- this also happens when the dishnet receiver is on. anytime the sound gets higher than 25..those black llines appear.
So, here is when I have done. I replaced front speaker (old anyway) with new shielded sony front speakers.
I use the TV's speaker as a center channel (recommend by manufactor) and disabling it in the setup does not effect the outcome.
Rear speakers should not be a problem, so I will not even bring them up.
I do not understand why this is happening...oh, I also wired a new 20amp circuit for the tv so it is not sharing with the rest of the components.
What stinks is I have close to $4,000 into this project and watching movies and/or sat tv is not enjoyable...Do you have any suggestions as to get this fixed. I am willing to try just about anything (as long as it is not out of my budget or my wife will probably kill me)
Thanks again and look forward to getting responses.
Tony
Here is my setup:
Tony
