brentl
- May 7, 1999
1991 Pontiac 600LE 3.1.
My ball joints are shot.
Can I replace them myself??
Are Moog parts better than OEM?? They are a little cheaper!
Ever heard of "half ball joints" ?? Literally half a ball joint.
Are they safe.
I'm only keeping the car for another year and the "half" ball joint are covered for a year.
Last thing, My wheel bearing on the right side is also shot, Expensive?? and can I do it??
Thank you
Brent
I have gone as far as replacing a clutch in a Civic, so I have some mechanical aptitude .
Are they safe.
Thank you
Brent
