I need an amplifier for my new speakers!? (1 Viewer)
DLLN
Dillon
Hi, I just bought Yamaha NS-AP2400 Speaker System, the only thing is I do not have a power source for them yet and I don't know much about speakers so I'm not sure what to get. There are six speakers so I assume the amp will need 6 inputs. Here's two sites to check out the speakers and there specs. I know that their satellites, but I'm not really sure what that means. If the amp is to strong/weak for the speakers will that ruin them? I think their 30-100 watt speakers but I don't know for sure. I don't really have that much money to spend, so I tried this old Pioneer amp that I had, but it's a 530watt amp, so the sound was extremely faint.
1) http://www.epinions.com/Yamaha_NS_AP2400...
2)http://www.4electronicwarehouse.com/cont...
THANKS A LOT
DILLON
Ed Moxley
Eastern NC
Ed
Neither one of your links take you anywhere that has speakers.
Check out this, and the following pages there:
Amazon.com: Receivers & Amplifiers: Component Receivers, Component Amplifiers, Stereo Receivers & More
Any of the 5.1 or 7.1 receivers there should work fine for you, depending on how much money you have to spend. Amazon.com is a very reputable site.
Good luck!
thinksinc
