felix_suwarno
- Dec 2, 2001
hi guys.
i need a dvd player with about 250 gigs of hard drive inside to record my wife's favorite tv program. we are also going to use hdmi or perhaps dvi ( if necessary ), because we want to use a 42 inch high def plasma from either panasonic or lg. we havent decided on which plasma...but i want to use it for either xbox360 or nintendo revolution or even ps3.
any recommendation?
can the hard drive be used to store WAV files? i just ripped every cd i have, and i want to have a music server as well.
as long as the price for the dvd player is less than 1500 dollar, i will consider it.
thank you
any recommendation?
thank you
