I need a DVD player with excellent video....
Discussion in 'Playback Devices' started by Frank_S, Oct 14, 2003.
  1. Frank_S
    Frank_S Supporting Actor
    Oct 28, 1999
    565
    I want to buy a DVD player that has excellent video, I don't want or need DVD-Audio or SACD, just a solid DVD player with the best video reproduction. I currently have a Toshiba SD-5109(1st generation)and Toshiba TW40x81 RPTV.
    What player would you recommend? I am only interested in buying a new player, I don't want to purchase a used one. Thanks in advance! [​IMG]
  2. Kage
    Kage Stunt Coordinator
    Mar 16, 2003
    127
    You should get the Denon DVD-1600. It has excellent picture quality and excellent sound for the price range it is in.
  3. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    Look for a player with a Faroudja Chip, I believe the sign for that on a player is iDOC (something like that)
  4. Frank_S
    Oct 28, 1999
    565
    I'm considering the Philips 963SA, I would rather have SACD than DVD-Audio. The downside to the Philips is that the transport "clicks" fairly loud, although I have'nt had the chance to check 1 out yet for myself yet. I also read that the "Tomorrow Never Dies" DVD causes the Philips to show the multi-angle icon throughout the entire movie and you can't get rid of it. I had this same problem with my Toshiba SD-5109 but if I turned the unit off and restarted the DVD, it worked fine.
    Any thoughts on the Philips 963SA? [​IMG]
  5. Kage
    Mar 16, 2003
    127
    The Philips 963SA has no open/close button on the remote, it has a very complex menu/setup screen, and its glitchy.
  6. Frank_S
    Oct 28, 1999
    565
    I don't care about the open/close feature but could you explain the "Glitchy" issue, that bothers me. [​IMG]
  7. NicholasL
    NicholasL Second Unit
    Apr 3, 2003
    298
    Denon 3800 or the new 5900 if you can pony up the cash. The 3800 (discontinued but amazing if you can find it) uses the pure progressive silicon image chip, while the 5900 i think will be using the faroudja DCDi chip.
  8. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    The 5900 uses the Silicon Image de-interlacer, not the Faroudja DCDi.
  9. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    1,771
    14
    610
    Jeremy
    The 5900 has the best pic I have seen yet. (and Ive seen alot)
  10. Stacy Huff
    Stacy Huff Second Unit
    Jul 13, 1999
    378
    The Denon DVD-5900 has Faroudja deinterlacing and scales through its DVI output, but that is irrelevant for your TV. It is a universal player. The MSRP on the 5900 is also about $2000.
    The Denon DVD-2900 uses the Silicon Image deinterlacer and produces a great progressive picture. It does have the alt-flag issue. It is a univeral player and lists for about $1000. Denon also has the 2200 universal player which looks like it probably has the same video section as the 2900. It goes for $600 or so.
    The Denon 1600 is no longer being produced, but if you can find one it uses the Faroudja DCDi chip and has the same MPEG decoder found in the Panasonic RP82. You can still find it around for $300 to $400, although it is getting scarce so you may have to buy used.
    For what it's worth, I have the Panasonic RP82 (essentially the same deinterlacing/video performance of the Denon 1600 according to the guys at Secrets) and the Denon 2900 hooked up to my Toshiba TW65X81, which is I believe the bigger version of your TV. I think either produces a terrific picture and that you would be happy with either.
  11. Jon_Miller
    Jon_Miller Auditioning
    Oct 15, 2003
    10
    At this point in my life, I cannot justify paying over $300 for a DVD player.
  12. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    See my post here
  13. Travis_R
    Travis_R Stunt Coordinator
    Oct 27, 2002
    247
    What model LiteOn DVD player did you get? I have a mitsubishi HDTV.
  14. jeff peterson
    Nov 29, 1998
    675
    The LVD-2001
  15. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    I keep seeing alot of posts about the Liteon, Jeff. One member even said it performed better than the Panasonic RP-91. I have a hard time believing it, but so many different people are extolling its virtues, I just might have to try one.
    DJ
