I just tested my 6-driver IB wall ... my head hurts (1 Viewer)
Geoff L
Geoff
Can't you wire, what is now 9 drivers I belive, to use (all coils) and still end with either a 3-ohm or 6-ohm load?
What ohm-load are looking for the plate amp-250 to drive, (3 or 6) in the end wiring result?
Sorry if I am missing something, just curious as to why you would not use all coils as I am sure the drivers TS-parameters are taken with coils in parralle...?
Coils are 3-ohm a side right?
Geoff
Javier_Huerta
Jerry, you are correct. By using only one VC, I double the Qts of the system, therefore extending low-end response.
Manuel Delaflor
Javier!
I didn't know you were working on this.... do you still have the IB working? Maybe I should think again in that HED12... where did you get it at 60bucks?
Javier_Huerta
Hola Manuel!
I got it at Santa Fé's Audiomundo... curiously enough, it was the cheapest place (cheaper than República del Salvador, even).
They are now $70 a piece.
I couldn't mount them. I didn't have enough money to finish my home, so I'm selling it :frowning: I'm now trying to figure out where to mount the stuff, if at all. I can't believe I can't find a place for my IB!
I'm happy with the HED's, though... in free air, they take a lot of abuse from my PE 700-394 amp. This is just speculation (I'll find out for sure in a couple of weeks), but I think a pair of these in the right box might be able to sound pretty nicely. :)
Manuel Delaflor
Sorry about your house :frowning:
What about a dipole sub? that would be an interesting proyect... don't know if those drivers would work though
vasyear
