I Have Turion 'Mobile Technology'- What Can I Do With It?
Discussion in 'Computers' started by James Edward, Feb 1, 2006.
  1. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    I just bought a laptop (Compaq V2570NR), and it has AMD's Turion mobile processing feature, along with a wireless card.
    What exactly can I do with these? I'm figuring the wireless card enables me to receive data if I have a home wireless network, but what about the 'mobile processing'?
    If anyone can shed light, I'd appreciate it. I initially bought the laptop to program remotes, but figure I may be able to avail myself of these other features...
    Thanks for any replies.
  2. Lance_R
    Lance_R Stunt Coordinator
    Dec 26, 2000
    130
    Basically you get nothing extra. The mobile processing uses less battery power. So if anything you should get a few extra minutes out of your battery.
    Turion is AMD's version of Intel's Centrino.
  3. JasonWW
    JasonWW Agent
    Jul 18, 2002
    34
    It's basically a lidless Athlon 64. It runs at a much lower voltage and produces 25w-35w of heat max. So it is very conservative in power usage as well as runs very cool. It's supossedly better than the Intel Centrino as far as power vs. consumption. It can also throttle itself down when it has no load on it, again making the battery last longer.
    Don't worry, you got a good CPU. Some folks are even putting the Turion in their desktops to make a silent PC.
