Marcus Lewis
- Oct 27, 2001
How can I best achieve this?
My Rotel RSX-965 manual suggests :
An alternative configuration for setting up front SMALL speakers with a subwoofer would be to follow the speaker manufacturer’s instructions, wiring the SMALL speakers to the subwoofer’s crossover and then connecting the subwoofer directly to the front speaker connection terminals. In this arrangement, the speakers would be classified as LARGE and the subwoofer setting would be OFF for all surround modes. No information will be lost during playback because the system knows to redirect the bass information to the front LARGE speakers. This configuration may be optimal
for many users as it can improve the way the bass integrates
into the listening room and ensure correct satellite speaker operation by using the speaker manufacturer’s own crossovers.
Sounds good, unfortunately my S1000, 46+combo does not have a crossover ... What external item can I use instead?
Thanks in advance ... This will likely be my last hurdle before audio bliss ... I hope ...
