mgh
- Jan 7, 2007
- mike
Sorry All, but I'm kind of lost here.
First problem is I do not have all my components yet, so do not know exactly what I'll have for outputs. Also, I don't know what type of connections are prefered for best quality.
Are all the "normal" plugs, for component video, SACD, subwoofer all the same size? If so, does it matter what kind of cable I'm using? In other words, anything like an RC cable will work? Should I buy new cables? Will these cables affect the quality of the signal?
I found monoPrice.com but I don't know what to search for, 'cause I don't know what the cables are called. When I searched for "optical audio" I got a page showing all kinds of cables, and since I don't kow what they are all called or used for, I was still lost.
How important is the quality of speaker wire? Can someone give me a recommendation for speaker wire?
Thanks for the patience with me.
